Wires
Started by Kopfjäger, January 04, 2015, 09:44:49 AM
Kopfjäger
Cleaned up some wiring. You can see all the wires coming up from the rear, speedo, rear brake light, neutral. There is also the original tab for the reservoir behind the wires. All the wires are mil spec now and routed through the frame gusset in one sheath. The top of the wire you see in this pic is hidden by the tank when it is down.
lazylightnin717
Details my friend.
You've dotted the i's and crossed the t's
[thumbsup]
Comes a time
Says don't you see
Gotta' make it somehow
monsta
looks good..
what about the earth to the engine, where did ya run that?
Kopfjäger
Quote from: monsta on January 04, 2015, 07:38:45 PM
looks good..
It's getting moved. I'll get pics later
I'll be impressed when you convert the frame to a RF bus and have no wiring at all.  :-)
Wzed
It keeps getting better.  Who's doing the work?  Have you thought about using the new Motogadget switchgear?
Kopfjäger
A friend of mine is doing the work. We looked at it, but vetoed it.
Wzed
Quote from: kopfjäger on January 05, 2015, 06:53:37 PM
Because the buttons are too small?  That's what I'm worried about - they look hard to use while wearing gloves.  Where did you mount the M-unit and other electrics like the rectifier, battery, etc.?  Did you use stock locations, or move them someplace else?
Kopfjäger
Kopfjäger
Willthedub
Tidy work  [clap]
What connectors are these?
I believe they are Deutsch.
Only the best for our Kopf.  ;D
Kopfjäger
Kopfjäger
