April 27, 2024, 09:26:56 PM
Frame cracked!
Topic: Frame cracked! (Read 5797 times)
Dmitry
Frame cracked!
February 14, 2015, 01:23:50 PM »
Hello everyone!
On my Ducati Monster M900 (1997) cracked frame. You can see it on the photos. Crack was discovered after buying the motorcycle. What do you think, how long i can ride on this frame, if I ride on good roads?
Photos:
http://ipic.su/img/img7/fs/1.1423948994.jpg
http://ipic.su/img/img7/fs/2.1423949008.jpg
http://ipic.su/img/img7/fs/3.1423949022.jpg
Re: Frame cracked!
February 14, 2015, 01:48:41 PM »
Weld ASAP! Also move post to Tech.
Re: Frame cracked!
February 14, 2015, 03:43:19 PM »
Quote from: howie on February 14, 2015, 01:48:41 PM
Yes, get that welded up, do not ride it that way.
Confirm that both motor mount bolts are not broken, and are tight.
Also inspect the mounting areas on the crankcase for cracks.
Re: Frame cracked!
February 14, 2015, 07:11:57 PM »
ouch, that's pretty bizarre
monsta
Perth, Australia.
Re: Frame cracked!
February 14, 2015, 11:36:43 PM »
Been known to happen before... this was mine,
I re-inforced it (plus the lower X section and braced the headstem) with some gussets for the fix...
Last Edit: February 14, 2015, 11:46:19 PM by monsta
Dmitry
Re: Frame cracked!
February 15, 2015, 02:31:22 AM »
Quote from: Speeddog on February 14, 2015, 03:43:19 PM
What do you think about this?
http://ipic.su/img/img7/fs/IMG_2258.1423996266.jpg
Dmitry
Re: Frame cracked!
February 15, 2015, 02:37:09 AM »
Quote from: monsta on February 14, 2015, 11:36:43 PM
Thanks for the photos! I will do about as:
Dmitry
Re: Frame cracked!
February 15, 2015, 02:41:07 AM »
How to think, how could this happen?
monsta
Perth, Australia.
Re: Frame cracked!
February 15, 2015, 02:52:04 AM »
Quote from: Dimon26 on February 15, 2015, 02:31:22 AM
how thick is the gusset you have there?
monsta
Perth, Australia.
Re: Frame cracked!
February 15, 2015, 02:55:08 AM »
Quote from: Dimon26 on February 15, 2015, 02:41:07 AM
fatigue... High stress area... poor welds....
combination of all?
Dmitry
Re: Frame cracked!
February 15, 2015, 03:15:13 AM »
Quote from: monsta on February 15, 2015, 02:52:04 AM
5 mm. it's okay?
monsta
Perth, Australia.
Re: Frame cracked!
February 15, 2015, 03:35:29 AM »
yep...
Dmitry
Re: Frame cracked!
February 15, 2015, 05:03:17 AM »
How long you ride with crack? When found her...
Re: Frame cracked!
February 15, 2015, 06:00:40 AM »
I would not go any further than nursing it home if I didn't have to go far. Once it cracks through you will be on the ground. Also, do follow Speeddog's advice to check the motor mount bolts and case. Looseness there can cause that crack.
Blackout
Re: Frame cracked!
Reply #14 on:
February 15, 2015, 08:59:58 AM »
Mine has been cracked at the same site on both sides for years. Probably pretty reckless on my part but I still ride the piss out of it. I'll have to pull the engine to gusset weld it.
2003 Ducati Monster 800
2003 Honda CR250
2008 KTM 990 SuperDuke
