Lazy Squid
Started by CookieMonster, August 12, 2016, 10:46:14 AM
CookieMonster
Ok so I was gonna get some gas the other day in my truck when I happen to stumble upon a lazy squid in the wild at the light...WHY?!
"Friend don't let friends ride stock"
-S2R1k 992 DESMO LIFE
Heath
WTF?? This make no sense to me.
2007 Ducati Monster S4RT
Kopfjäger
Not an issue at all. I know a really short dude that does it on his motard. Has it down to a science.
Mhanis
It is a bit goofy but not the worst transgression ever.  ???
Mark
Pete Townshend
Curmudgeon
Bit lame but I have to do this to trigger the stoplights around here if I'm alone.  >:( Believe the law in VA allows me to take my chances after ~ 2 minutes, or something like that..., but I'd rather the light in my favor...
CookieMonster
Quote from: Curmudgeon on August 13, 2016, 10:56:43 AM
Kick stand down will help the light change? How so? Pardon my ignorance. However, I don't think that excuse is valid in his case considering that he has two cars in front of him and me behind him waiting for the light as well.
I will not make a db comment like "dam Asian squid" as a reference to their bad driving skills because I am sure there are great Asian drivers out there. That would just be so wrong of me to say even though he is Asian.
Curmudgeon
Quote from: CookieMonster on August 19, 2016, 10:44:53 AM
Read it somewhere else a long time ago. Not 100% but does work where the car sensor wires are embedded in the road as they are around here. Just enough metal I suppose where otherwise it only recognizes a ton of steel.
Kopfjäger
Why do you even give a make the beast with two backs that some dude sits on his bike with the kickstand down?  ???
We have the same issue. Im gonna try the kick stand trick, but not with me sitting on it as I have an Evo.
You need a ferrous kick stand.  Eve then, no guarantee, at best, an added glimmer of help.  And, yep, you need to be over the coil.
Hyper has a steel one. Often you see telltale marks in the tarmac. [thumbsup]
Rameses
I will not make a db comment like...
[roll]
Then how about you just don't say it?
Adding the disclaimer doesn't negate the fact that you typed it out and then hit the post button.
"I'm not a racist, but [insert racist comment]" is still a racist comment.
