Look what I found in the shed
Started by Pinion, October 26, 2019, 09:48:45 AM
Pinion
Well dug this thug out this morning, hasn't seen the light of day since spring 2018. Time to freshen her up. I will try to keep it just that, but last time I tried that is didn't stay that way.
Anywho;
As is sits, 95 frame, 2001 900ssie motor, air box delete, power commander, marchesini wheels, gecko racing rear sets, GPR exhaust.
Stay tuned kids, this could get interesting. But hopefully not. As they say, “hope is undiscovered disappointment “
Untitled by D charles, on Flickr
Will trade toilet paper for parts
greenohawk69
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty:  Soap, Ballot, Jury and Ammo.  Please use in this order.  -- Ed Howdershelt
Pinion
Need a good source for top end and cylinder base gasket
greenohawk69
Not sure, but I'd probably start my search with the forum sponsors.
Pinion
Quote from: greenohawk69 on October 27, 2019, 06:57:01 AM
Did that, can't get cylinder base gaskets with anyone
Pinion
Well, digging around in this this morning
I found these goodies, which also had a Moto gadget rfid kit :o, a gps mini speedo and mini tach, and other bits
greenohawk69
Based on a google search while on the throne, it appears you can re-use the base gaskets and use Ducatibond 1215 or Threebond 1184 (cheaper and can be found in parts stores).
https://www.ducati.ms/threads/cylinder-base-gasket-install-dry-or.557713/page-2
Pinion
Quote from: greenohawk69 on October 27, 2019, 08:12:08 AM
Based on a google search whole on the throne, it appears you can re-use the base gaskets and use Ducatibond 1215 or Threebond 1184 (cheaper and can be found in parts stores).
Interesting
, the motor has about 7k on it and vert cylinder leaks pretty bad. I will try to hunt down the sealer
Still not a fan of re using gaskets of any kind
Thanks again.
Yup...done all the time.
Pinion
Ok fine, I surrender the issue to the distinguished gentleman on the floor.  [bow_down]
Quote from: Pinion on October 27, 2019, 11:00:43 AM
Valve cover gaskets can be re-used, as well. They'll eventually need to be replaced, but a base gasket is more of a spacer than anything. It can be re-used indefinitely if sealed properly.
Pinion
#11
Yes, the valve cover gaskets are metal as well
Read this thread:
http://ducatimonsterforum.org/index.php?topic=23736.0
Yes, the base gasket is often reused and will probably work unless badly bent, folded or otherwise mutilated.  Because of my overcautious nature I would, unless  ridiculously expensive or unobtainable would probably replace it.  They are not that expensive and you can get them from a dealer.  You can look here, but strangely enough they don't list an '01 900SS
Pinion
#13
Quote from: howie on October 27, 2019, 09:33:51 PM
That's the issue I'm running into, an 01 ss ie isn't listed. Also parusing through the inter web, seems to be an issue with 00-01 2v and s4
I have a new set from a 96, going to see if they fit
Make sure they're the same thickness, or you'll change the squish.
