December 27, 2024, 10:27:56 AM *
News: Please Help
Pages: 1 2 [3] 4 5 ... 15   Go Down
Author Topic: Look what I found in the shed  (Read 31072 times)
Pinion
« Reply #30 on: October 29, 2019, 09:53:21 PM »
I will look for rebuild kit, but it’s 20 yrs old. Aluminum fatigue might be a factor. Don’t want to reduce effort, but I’m not running stock clutch springs
Will trade toilet paper for parts
Pinion
« Reply #31 on: November 10, 2019, 08:46:40 AM »
Yup,
That kind of fun today
Trying the simple green crystal foam
Untitled by D charles, on Flickr
Pinion
« Reply #32 on: January 10, 2020, 06:49:44 AM »
Today class, we are doing a retro head swap
The 95 heads look way cooler then the 2000.
Geometry is all the same
I’m hoping the Ducati gods will intervene if I’m dead wrong
E26FB304-A2A2-4B6A-A61E-D37E57882274 by D charles, on Flickr
« Last Edit: January 10, 2020, 10:34:00 AM by Pinion » Logged
« Reply #33 on: January 10, 2020, 07:02:20 AM »
Aren’t 2000-2002 900 engines fuel injected?  If so, it has better cams.
Pinion
« Reply #34 on: January 10, 2020, 07:17:21 AM »
This is a 2001 900 ss ie motor, I should jus be able to swap cam right
« Last Edit: March 15, 2020, 10:44:09 AM by Pinion » Logged
Pinion
« Reply #35 on: January 10, 2020, 09:49:51 AM »
Cam swap done, head swap gtg. Cam on right the 2001 900ssie, cam on left 95 900ss
9140B86B-0DEA-480E-A142-5CC19E2710D5 by D charles, on Flickr
3CA506C9-E084-40D0-8BA4-21BD257B4F1A by D charles, on Flickr
B0EFF78B-A900-4D43-8A35-B3A03B4ABD21 by D charles, on Flickr
« Reply #36 on: January 10, 2020, 10:41:57 AM »
Double check the oil galleries line up between the barrels and heads just to be sure.
« Last Edit: January 10, 2020, 10:55:13 AM by koko64 » Logged
Pinion
« Reply #37 on: January 10, 2020, 10:56:19 AM »
They do, thanks.
1st thing I did was to check all geometry
« Reply #38 on: January 10, 2020, 11:05:11 AM »
 waytogo
The big changes to oil passages were at the barrel/crankcase interface. I couldn't remember for sure about the barrel to heads. The old motors had oil cooling galleries in the barrels and not just oil drainage. Pretty cool uh?
Pinion
« Reply #39 on: January 10, 2020, 11:23:04 AM »
waytogo
No major changes till 02, big change from a 95 to an 2000 was eliminating the oil lines on the barrels. All interior oil passages, valving, cam dimensions and other ports are the same. I’ve been wanting to try this for a couple yrs, just happened to raid shed and there they were, rebuilt and ready to go. And if it blows up, I was wrong, lol
« Last Edit: January 10, 2020, 11:27:08 AM by Pinion » Logged
« Reply #40 on: January 10, 2020, 03:25:50 PM »
The Dakar Elefants enjoyed the oil cooled barrels. Oilways circled the barrels on the way down. Similar to Suzuki's air/oil cooled system.
Those ie cams are useful. Have prescribed them for a very hi comp carbed 944 which needed more cam to actually turn over! It relieved the cranking pressure and gave a useful bump in peak power too. The bike also ran smoother with them, so its not just the efi alone that makes em smoother imo.
Do you have a 750 to try the 900 cams with?
Pinion
« Reply #41 on: January 10, 2020, 06:32:24 PM »
No I do t know what a 750 is, lol
Pinion
« Reply #42 on: January 11, 2020, 12:14:45 PM »
Mmmmm flywheel
048E8A40-45FB-450D-81DB-1CDC2CF9B33D by D charles, on Flickr
« Reply #43 on: January 11, 2020, 08:42:08 PM »
That's an adapter.
Pinion
« Reply #44 on: January 12, 2020, 03:57:28 AM »
That's an adapter.
That’s a Nichols flywheel
https://www.bellissimoto.com/parts/engine/lightweight-flywheels/nichols-lightweight-flywheel-for-1999-fuel-injected-motorcycles-1
Pages: 1 2 [3] 4 5 ... 15   Go Up
