April 29, 2024, 07:31:49 AM
Look what I found in the shed
15
Topic: Look what I found in the shed (Read 27635 times)
Pinion
Re: Look what I found in the shed
Reply #15 on:
October 28, 2019, 04:07:13 AM »
Quote from: ducpainter on October 28, 2019, 03:45:37 AM
Make sure they're the same thickness, or you'll change the squish.
Yes
Will trade toilet paper for parts
Reply #16 on:
October 28, 2019, 04:11:15 AM »
The 2001 900SS did though. I think the original gasket was modified due to those leaks. Stock gasket is 4mm.
Online
Reply #17 on:
October 28, 2019, 06:24:11 AM »
IIRC, an o-ring was added to the oil return hole to stop the leaks. I don't remember if there was a recess machined into the cylinder, or the cases.
Nick might.
Pinion
Reply #18 on:
October 28, 2019, 08:12:42 AM »
I’ve read here either ball bearing or set screw
Pinion
Reply #19 on:
October 28, 2019, 08:14:41 AM »
And then comes that moment.......... should I.............
Untitled
by
D charles
, on Flickr
greenohawk69
Reply #20 on:
October 28, 2019, 08:36:19 AM »
Should you...put tires on? I'd say yes. Yes to doing it.
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty: Soap, Ballot, Jury and Ammo. Please use in this order. -- Ed Howdershelt
Reply #21 on:
October 28, 2019, 08:47:56 AM »
'00 900SS had an O-ring, '01 did not, pretty sure all models went without it starting around then.
There's a pocket machined in the cases for the O-ring on bikes that had them.
I think the elimination of it was a cost saving driven decision.
'00 900SS - 78610471A - with oring
'01 900SS - 78610601A -NO oring
'02 SS - 78610682A -NO oring
Base 'gasket' is in reality a shim, sealing is achieved with Threebond sealer or similar.
One can eliminate it entirely if needed to get proper squish.
Valve cover gaskets that are the 'rubber' coated steel can be cleaned and re-used many times.
No sealer necessary.
I trash all fiber/paper valve cover gaskets I find, and replace with the rubber coated steel.
Pinion
Reply #22 on:
October 28, 2019, 09:18:07 AM »
Quote from: greenohawk69 on October 28, 2019, 08:36:19 AM
Pinion
Reply #23 on:
October 28, 2019, 09:19:44 AM »
Quote from: Speeddog on October 28, 2019, 08:47:56 AM
Agreed on valve cover gaskets, coming from Germany. I have also read all of your posts on this subject
Pinion
Reply #24 on:
October 28, 2019, 09:24:45 AM »
Last time I started effing around with my bike, this happened
Untitled
by
D charles
, on Flickr
Pinion
Reply #25 on:
October 28, 2019, 12:20:41 PM »
And now I go in the other direction
Untitled
by
D charles
, on Flickr
Pinion
Reply #26 on:
October 28, 2019, 01:29:03 PM »
Any outstanding opinions on clutch slave cylinders, stock one is leaking and want to do better
Online
Reply #27 on:
October 28, 2019, 01:54:12 PM »
I like stock clutch slaves.
Reply #28 on:
October 29, 2019, 07:40:10 PM »
+1.
Reply #29 on:
October 29, 2019, 08:59:56 PM »
Unless you want to reduce effort stock is fine and can be rebuilt easily as long as the metal is good on the older slaves.
If you want reduced pull you might run into clutch drag problems since travel is reduced. I was a Yoyodyne fan, but he no longer manufactures them. Maybe this one?
https://monsterparts.com/products/oberon-clutch-slave-cylinder?_pos=1&_sid=6cc784c2f&_ss=r
15
