December 27, 2024, 09:10:46 AM
Look what I found in the shed
12
13
14
15
Topic: Look what I found in the shed (Read 31045 times)
Pinion
Re: Look what I found in the shed
Reply #180 on:
April 16, 2020, 12:47:26 PM »
A 2001,
It seemed to do ok with the filters I had, just looking to get best I can out of what turned out to be a bit more spending then planned
Will trade toilet paper for parts
Reply #181 on:
April 16, 2020, 12:49:21 PM »
Quote from: Pinion on April 16, 2020, 10:33:40 AM
Hope the 11:5 burn 93 better, I like combustion, not explosion
I call it spell inject at this point
At 11.5:1 93 is the correct choice. You're lucky it's EFI. The carbies get really difficult to tune. Where are you having your ecu mapped?
Reply #182 on:
April 16, 2020, 12:51:00 PM »
Quote from: koko64 on April 16, 2020, 11:41:45 AM
The 900ie ignition curve seems more tolerant of hi comp but run your 93 MON. No maps for a 2000 model? The pods (especially small ones) without velocity stacks under them don't flow that well, so not as lean as kits like Corse Dynamics, Beast, Beast R, WASP, Ducshop, etc. With little pods clamped on the throttle bodies you might just have to play with trim or used a canned map for a 2000 model.
Starting should be without too much strain as the hot ie cams bleed off some cranking pressure.
Brad Black = BikeBoy.org
We don't use MON. We use an average of Research and MON.
Reply #183 on:
April 16, 2020, 01:13:05 PM »
Hmm. What's that called?
Pinion
Reply #184 on:
April 16, 2020, 01:13:37 PM »
Quote from: ducpainter on April 16, 2020, 12:49:21 PM
Still looking for someone
And the engine is an SS not Mon
Hard to remember being a monster forum, lol
Reply #185 on:
April 16, 2020, 01:16:05 PM »
Edit: I based my replies on a Monster ECU. What ECU are you using?
Last Edit: April 16, 2020, 02:04:14 PM by koko64
Pinion
Reply #186 on:
April 16, 2020, 01:18:29 PM »
I know, went to pc site and SS wasn’t even in the options list
Reply #187 on:
April 16, 2020, 01:22:02 PM »
Quote from: koko64 on April 16, 2020, 01:13:05 PM
RON+MON/2...
Reply #188 on:
April 16, 2020, 01:59:00 PM »
Quote from: ducpainter on April 16, 2020, 01:22:02 PM
RON+MON/2...
Pinion, what ECU are you using? Did it come with the motor and loom or a Monster ECU? I've lost track.
Pinion
Reply #189 on:
April 16, 2020, 04:01:44 PM »
Lol
Engine, fuel delivery and ecu are 2001 900 ss ie
Reply #190 on:
April 16, 2020, 04:34:26 PM »
Should be Marelli a 1.5 ECU. Used on 900ie Monster and Supersport til the change in 02 to the 5.9 ECU. That should open up a few map options across those models I guess.
Reply #191 on:
April 16, 2020, 04:46:53 PM »
I see that many maps in the Powercommander library are now deleted. Shame. The website has changed a lot.
Reply #192 on:
April 16, 2020, 05:12:06 PM »
To repeat:
Brad Black = bikeboy.org
Also, for that vintage there were no differences between SS900ie & M900ie.
Pinion
Reply #193 on:
April 17, 2020, 03:02:34 AM »
Quote from: Duck-Stew on April 16, 2020, 05:12:06 PM
To repeat:
Timing, ignition, rev limiter, fuel delivery(ecu)
Monster rev limiter kicks in around 6500, ss 9500
Also gearbox ratio
I am so available to be wrong
Last Edit: April 17, 2020, 03:08:43 AM by Pinion
Pinion
Reply #194 on:
April 17, 2020, 03:32:18 AM »
To repeat:
Sent him a note, thanks
12
13
14
15
