Look what I found in the shed
Started by Pinion, October 26, 2019, 09:48:45 AM
Ddan
Quote from: Pinion on April 17, 2020, 04:02:34 AM
Timing, ignition, rev limiter, fuel delivery(ecu)
Monster rev limiter kicks in around 6500, ss 9500
Also gearbox ratio
I am so available to be wrong
2000 Monster Sie revs well past 6500, I'm thinking the rev limiter hits just over 8k
Ducati Monster Forum at
www.ducatimonsterforum.org
Pinion
Quote from: Ddan on April 17, 2020, 05:18:27 AM
I'm think of the carby  ;D, oops
Will trade toilet paper for parts
My carby has no ecu or rev limiter.
After 8K, all you're making is noise. ;D
2000  Monster 900   78 hp @ 6750 rpm
1999  Monster 900   74. HP @ 7000 RPM
2000  Supersport     80. HP @ 7000 RPM
Rumor has it the carbys had a 9K red line, Ive never seen that as an official Ducati spec.  As Nate said, over 8K is pointless.
I believe the difference between the Monster and Supersport is cams.
No carb rev limiter.  Just loss of power.
900 injected cams are the same between M & SS.
ECU's are different though.  Something about the harness pin-outs is different M to SS, and oddly '99 SS is different than '00-'02 SS bikes.  Another pin-out difference.
NOTE: almost all Ducati's got the immobilizer in '02.  The SS did not until 2003.
Pinion
Quote from: Duck-Stew on April 17, 2020, 03:02:00 PM
Correct
Main difference is injectors, gear box ratio and some mild mapping in ecu
Pinion
#202
If I found a DP ecu,I could get rid of the pc, also Guzzdiag has been suggested with tune pro to rewrite myself
I have a nos ecu coming, so I have 1 to mess with
l88m22vette
This makes me want to get a bunch of cheap used stuff to do an EFI conversion. I'm not going to, this is just an inspiring thread, you work a lot faster than me [roll]
2000 Monster 750, yellow/bronze, first bike!
Pinion
This is probably the simplest fi system, (and reliable)
Quote from: l88m22vette on April 19, 2020, 07:05:14 AM
EFI throttle bodies will not fit a carbureted frame.  I know.  I did it.  The tube which runs side to side (holds back of the air box) is straight on a carbed bike and curved on an injected bike.  If you can change the tube, change the wiring and change the tank, it can be done.
Quote from: Duck-Stew on April 19, 2020, 01:29:23 PM
Pay close attention to the man behind the curtain. ;D
Pinion
#207
Took this 95 carby and 2001 Efi
Although it was a complete motor swap
This thread is it's 3rd life
Untitled by D charles, on Flickr
900ss by D charles, on Flickr
And made this, no frame mods
IMG_2966 by D charles, on Flickr
Link to build
http://www.ducatimonsterforum.org/index.php?topic=75624.0
I know, I'm such a tool
That version was my favourite actually.
l88m22vette
[beer]
