December 28, 2024, 04:08:54 PM *
Pages: 1 ... 5 6 [7] 8 9 ... 15   Go Down
Author Topic: Look what I found in the shed  (Read 31196 times)
Pinion
« Reply #90 on: March 04, 2020, 04:02:32 PM »
900ssie ran 98 - 02.  There's a live parts diagram on an Australian dealer site - http://www.morningtonmotorcycles.com.au/ducati-spare-parts
Put in your year and model.
Parts,catalogs go to 2000 and that’s it in US
Will trade toilet paper for parts
Orange16
« Reply #91 on: March 04, 2020, 04:11:27 PM »
Ok.  Hope you can sort it out.
« Reply #92 on: March 04, 2020, 05:40:16 PM »
My data says LC41 is a 2001 900SS.
Pinion
« Reply #93 on: March 04, 2020, 05:45:20 PM »
Yes, I know
It was my bike
I can’t find 2001 900ssie parts manual or shop manual, they only go to 2000 for some reason
« Reply #94 on: March 05, 2020, 05:03:46 PM »
That’s the oil pump o ring.
This motor has no internal o ring.
F#*k beer, I went straight for the tequila
Took it apart unnecessarily based on a ducat type o
Then dropped the clip right after I put I back together, I will learn at some point, lol
I will do the rag th
ing, derp.
That was my concern . They can move during  reassembly with dire consequences. You goop it in place or it just stay stuck on if not replaced?
« Last Edit: March 05, 2020, 08:52:35 PM by koko64 » Logged
Pinion
« Reply #95 on: March 06, 2020, 09:07:10 AM »
Could be last straw time, wtf
39662DC2-D112-4FD6-84F4-97F89AB023FF by D charles, on Flickr
« Reply #96 on: March 06, 2020, 12:18:34 PM »
Can you see it on the other side?
Pinion
« Reply #97 on: March 06, 2020, 02:23:19 PM »
I would have to split the cases again
« Reply #98 on: March 06, 2020, 03:05:42 PM »
That's the starter mounting flange area, yes?
If so, the other side is behind the starter idler gear, so only the alternator cover.
I'd clean it up and JB weld it inside and out.
Pinion
« Reply #99 on: March 06, 2020, 03:45:26 PM »
I wish, lol
It’s actually on the case, not the flange. Other side is inside case. Have a micro camera I will get from the shop on Monday to see if it’s all the way through
575D81CF-68F9-4791-9356-3B6EBE82BDF9 by D charles, on Flickr
« Last Edit: March 06, 2020, 03:52:50 PM by Pinion » Logged
« Reply #100 on: March 06, 2020, 04:41:16 PM »
There's a 'well' on the other side of that crack, where one of the M6 case bolts goes into.
An earlier 900 case I have here the 'well' is ~10.8mm diameter, any JB weld in there just needs to be a hair bigger than the 10mm diameter head of the M6 bolt.
Or you could butter up an aluminum slug ~10mm OD, 6.5mm ID and maybe 12mm long with JB, butter up the 'well' inside, and use a slightly longer bolt. Still JB the outside too. There's no oil pressure there, it's just sitting in oil.
Pinion
« Reply #101 on: March 06, 2020, 04:50:53 PM »
Tanks,
I’ll jb weld it, and see how it does, if it continues I will flash tig it
« Last Edit: March 06, 2020, 04:53:58 PM by Pinion » Logged
« Reply #102 on: March 06, 2020, 05:23:58 PM »
If you can TIG it, do that first.
Once it's JB'd, I don't think you can get it clean enough to TIG.
Pinion
« Reply #103 on: March 09, 2020, 01:11:57 PM »
Funny, I workin my shop all day to make your sh#t, then I come home to my neglected bike
668036F9-A1D4-4EE0-8195-25A4E4F1FA3D by D charles, on Flickr
Pinion
« Reply #104 on: March 15, 2020, 10:30:30 AM »
Mmmmmmmotor
Still waiting on a few odds and ends to button up, but hey, it’s moving forward. What did you do doing your zombie apocalypse
3B24F2CD-8844-4538-8241-F491A6440EC8 by D charles, on Flickr
Pages: 1 ... 5 6 [7] 8 9 ... 15   Go Up
