October 20, 2024, 05:26:17 AM
Statler
ML builds an old truck
9
10
11
12
39
Topic: ML builds an old truck (Read 52971 times)
The best kind of whore is a
Re: ML builds an old truck
Reply #135 on:
January 08, 2022, 12:59:41 PM »
Quote from: ducpainter on January 08, 2022, 11:22:29 AM
I must be reading impaired. I didn't see where you asked that question in your post.
I though you wanted overall length.
I'm looking for wheel mounting face to wheel mounting face so I can confirm 17x9 with a 4.5" backspace and -.5" offset would work.
I'm figuring 48" bed width + 6" clearance between the wheel and the bed (60 total so far) +4.5" per side of backspace would intimately = a rear end that's 69" from where the wheels mount.
All theory so far.
Reply #136 on:
January 08, 2022, 01:27:46 PM »
Wouldn't that be axle flange to axle flange?
https://www.markwilliams.com/axle-ordering.html
Reply #137 on:
January 08, 2022, 01:34:20 PM »
Quote from: ducpainter on January 08, 2022, 01:27:46 PM
It would, yes. I'm using wheel mounting face and axle flange interchangeably.
Reply #138 on:
February 11, 2022, 01:08:19 PM »
Update!
I bought a set of F250 super duty axles and am in the process of rehabbing the rear.
It's a 10.5 Sterling with 13" disc brakes and dual piston calipers. 4.10 gear ratio.
Axles are 1.5", 35 spline and full floating. Everything about this axle is absolutely massive.
I got a Detroit Trutrac for it in today and when the carrier bearings show up next week I'll try my hand at swapping the diff and reusing the ring gear.
Reply #139 on:
February 11, 2022, 06:10:38 PM »
2022-02-11_09-07-22
by
Kevin Ames
, on Flickr
2022-02-11_09-07-46
by
Kevin Ames
, on Flickr
For $50 you can touch my
Reply #140 on:
February 12, 2022, 05:52:59 AM »
I killed one of those sterlings in my F350.
KRJ
'07 MTS 1100S , '03 XR650L , '78 KZ 1000
Reply #141 on:
February 12, 2022, 07:50:22 PM »
Depending on the mileage of these axles You might entertain the thought of a complete disassembly,
pinion bearings and hub bearings. Having rebuilt dozens of axles I have found it to be a better approach,
You will also need a case spreader to get it together with the proper bearing preload. Not knowing how
much experience You have I hope I am not out of line, but I have seen a lot bad "U Tube" rebuilds.
Dana Spicer instructions also apply to any Salisbury type axle,needs to be right for big HP...
" I believe You understand what You think I said, but I'm not sure You realize that what You heard is not what I meant " !!
Reply #142 on:
February 14, 2022, 02:40:58 PM »
Quote from: Davey Two Tractors on February 12, 2022, 05:52:59 AM
How?
Quote from: KRJ on February 12, 2022, 07:50:22 PM
Your not out of line, I appreciate the input. I have new carrier bearings coming but am going to try to leave the pinion alone. If it patterns good before and after the build I'll sleep mostly ok.
I may have questions for you later this week or early next week.
Reply #143 on:
February 14, 2022, 02:45:17 PM »
Quote from: Monsterlover on February 14, 2022, 02:40:58 PM
How?
Dave can break an anvil.
Reply #144 on:
February 14, 2022, 02:46:14 PM »
Quote from: ducpainter on February 14, 2022, 02:45:17 PM
I mean if your gonna be good at one thing go all in.
Reply #145 on:
February 14, 2022, 02:53:11 PM »
Quote from: Monsterlover on February 14, 2022, 02:46:14 PM
Yet, he can put a large object into orbit. Go figure.
Reply #146 on:
February 14, 2022, 03:00:43 PM »
Quote from: ducpainter on February 14, 2022, 02:53:11 PM
It's just in orbit. Doesn't mean it will work once it gets there
Reply #147 on:
February 14, 2022, 03:01:32 PM »
Quote from: Monsterlover on February 14, 2022, 03:00:43 PM
I don't think that part was in his job description.
Randimus Maximus
'01 996SPS
Reply #148 on:
February 14, 2022, 06:01:53 PM »
Quote from: ducpainter on February 14, 2022, 03:01:32 PM
Not saying there is a correlation (and I haven't a clue which company he used to work for), but this is suspect:
https://www.npr.org/2022/02/09/1079575679/spacex-40-starlink-satellites-destroyed
you may be a god
Reply #149 on:
February 15, 2022, 05:48:45 AM »
How?
One piece at a time. Knight of Ni may have been involved.
With a rubber hammer.
Totes.
They all worked
Sure was!
Quote from: Randimus Maximus on February 14, 2022, 06:01:53 PM
I never worked for them.
9
10
11
12
39
