August 17, 2024, 10:31:23 AM
Statler
ML builds an old truck
10
11
12
13
38
Topic: ML builds an old truck (Read 50206 times)
Re: ML builds an old truck
Reply #150 on:
February 15, 2022, 06:15:35 AM »
Good morning
The best kind of whore is a
Reply #151 on:
February 15, 2022, 06:29:08 AM »
Quote from: howie on February 15, 2022, 06:15:35 AM
Good morning
No coffee in this thread.
Post a pic of an old truck for penance. ..
A cool one.
Reply #152 on:
February 15, 2022, 06:41:01 AM »
Good morning
Oops
https://hdrcreme.com/photo-gallery/44713/old-truck-montana
Last Edit: February 15, 2022, 06:42:54 AM by howie
Reply #153 on:
February 15, 2022, 06:53:56 AM »
Redeemed
Randimus Maximus
Online
'01 996SPS
Reply #154 on:
February 15, 2022, 07:23:28 AM »
Quote from: Davey Two Tractors on February 15, 2022, 05:48:45 AM
I never worked for them.
you may be a god
Reply #155 on:
February 15, 2022, 07:26:51 AM »
Quote from: KRJ on February 12, 2022, 07:50:22 PM
Depending on the mileage of these axles You might entertain the thought of a complete disassembly,
pinion bearings and hub bearings. Having rebuilt dozens of axles I have found it to be a better approach,
You will also need a case spreader to get it together with the proper bearing preload. Not knowing how
much experience You have I hope I am not out of line, but I have seen a lot bad "U Tube" rebuilds.
Dana Spicer instructions also apply to any Salisbury type axle,needs to be right for big HP...
I had never heard of a case spreader until you mentioned it in your post. Did a little reading and it looks like a handy tool. I see a bunch of guys have used them or made their own with threaded rod and still others have elected to smack the carrier into place with a deadblow hammer. What are your thoughts on the hammer method?
Speedbag
And the Intrepid
Since 2004!
Reply #156 on:
February 15, 2022, 07:59:59 AM »
Best to use a case spreader.
For $50 you can touch my
Reply #157 on:
February 15, 2022, 09:03:00 AM »
Taking it into more pieces is always the way to get things on the road.
It'll probably be fine, and if not, it's easily replaceable.
Just give it a Krylon restoration and run it.
Reply #158 on:
February 15, 2022, 09:25:43 AM »
Quote from: Davey Two Tractors on February 15, 2022, 09:03:00 AM
I'm replacing the carrier and bearings with a Detroit Trutrac
KRJ
'07 MTS 1100S , '03 XR650L , '78 KZ 1000
Reply #159 on:
February 15, 2022, 10:01:20 AM »
Morning, the case spreader is needed to prevent the shims/ bearings from gouging the seating surface. Most often You have
to remove, replace the carrier several times to get the proper pattern. Changing the pinion bearings will help bring things back to
the factory spec. for those gears. You will want .010 -.014 in. carrier bearing preload if I remember right, hammering in and prying out
ain't a lot of fun. I would loan You mine but shipping might be too much from Colo. and their not hard to build. All part of the Fun.....
" I believe You understand what You think I said, but I'm not sure You realize that what You heard is not what I meant " !!
KRJ
Reply #160 on:
February 15, 2022, 10:41:22 AM »
Another thing while I've got time, I don't spend a lot of time trying to get the "perfect" pattern
with used gears. Focus on the drive side and get as close as possible, it will be fine. This looks
like a really cool project, hope this can be of some help
Reply #161 on:
February 15, 2022, 10:49:12 AM »
Quote from: Monsterlover on February 15, 2022, 09:25:43 AM
But what flavour Krylon?
Reply #162 on:
February 15, 2022, 02:43:31 PM »
Another vote for case spreader.
Randimus Maximus
Online
'01 996SPS
Reply #163 on:
February 15, 2022, 03:33:51 PM »
Quote from: Davey Two Tractors on February 15, 2022, 10:49:12 AM
you may be a god
Reply #164 on:
February 17, 2022, 03:59:09 AM »
I'll just get one of these
It'll be fine
10
11
12
13
38
