July 17, 2024, 09:20:56 PM
Statler
ML builds an old truck
36
37
38
Topic: ML builds an old truck (Read 48688 times)
Randimus Maximus
'01 996SPS
Re: ML builds an old truck
Reply #540 on:
April 10, 2024, 07:24:51 AM »
Quote from: Monsterlover on April 10, 2024, 05:37:35 AM
I'm just trolling
you may be a god
The best kind of whore is a
Reply #541 on:
April 29, 2024, 08:20:24 AM »
A lot has happened in the last few weeks.
Most notably is the front of the truck is back together and construction of exhaust piping and intake piping is currently underway.
Also, a tree fell on my garage. No real damage to anything except the edge of some sheet metal on the roof. I got really lucky. Maybe it was related to that one tree at Dave's house?
For $50 you can touch my
Reply #542 on:
April 29, 2024, 01:15:35 PM »
Quote from: Monsterlover on April 29, 2024, 08:20:24 AM
We could start a club!
Reply #543 on:
April 29, 2024, 07:10:24 PM »
I don't want to be a member.
Reply #544 on:
May 05, 2024, 09:52:10 AM »
Lots of pics to post today.
Added a Holley accessory kit that keeps everything tight to the center of the block. Important when you have a narrow hood and want to keep it
PXL_20240406_164118715
by
Kevin Ames
, on Flickr
PXL_20240406_213556848
by
Kevin Ames
, on Flickr
PXL_20240410_233607687
by
Kevin Ames
, on Flickr
A nice radiused wiring pass through I found online
Kevin Ames
, on Flickr
PXL_20240412_165332775
by
Kevin Ames
, on Flickr
by
Kevin Ames
, on Flickr
PXL_20240412_165314940
by
Kevin Ames
, on Flickr
PXL_20240416_001815206
by
Kevin Ames
, on Flickr
Built a hinged panel to mount my fuse block and Holley dominator.
PXL_20240407_230541980
by
Kevin Ames
, on Flickr
Managed to weld a .045 aluminum hinge to .125 plate. Ugly but functional
PXL_20240412_194656244
by
Kevin Ames
, on Flickr
PXL_20240414_171422019
by
Kevin Ames
, on Flickr
PXL_20240414_172256706
by
Kevin Ames
, on Flickr
PXL_20240414_174100739
by
Kevin Ames
, on Flickr
PXL_20240414_172305786
by
Kevin Ames
, on Flickr
PXL_20240414_172215573
by
Kevin Ames
, on Flickr
1200cc FIC injectors mounted up. I had to drill and tap the intake since the two sets of holes they provide were either too tall or short to with with these injectors
PXL_20240417_235720507
by
Kevin Ames
, on Flickr
PXL_20240418_000225986
by
Kevin Ames
, on Flickr
Were I not running a hood these manifolds could have made a nice start for me. The fitment was wrong so I sent them back. I ended up finding a set of stainless manifolds on eBay and used them as the beginning of turbo plumbing
PXL_20240410_232723437
by
Kevin Ames
, on Flickr
PXL_20240410_232729423.MP
by
Kevin Ames
, on Flickr
PXL_20240414_201136912
by
Kevin Ames
, on Flickr
T3 to v band adapters I found
PXL_20240420_143129400
by
Kevin Ames
, on Flickr
PXL_20240420_151734891
by
Kevin Ames
, on Flickr
PXL_20240420_192754152
by
Kevin Ames
, on Flickr
PXL_20240420_192801767
by
Kevin Ames
, on Flickr
PXL_20240420_222712032
by
Kevin Ames
, on Flickr
PXL_20240420_223305889
by
Kevin Ames
, on Flickr
PXL_20240420_222425273
by
Kevin Ames
, on Flickr
PXL_20240420_223254275.MP
by
Kevin Ames
, on Flickr
Spot welds on a v band broke so I welded it. I'm going to go over all the other clamps as well. Can't risk a failure while driving
PXL_20240420_195324242
by
Kevin Ames
, on Flickr
PXL_20240420_205729268
by
Kevin Ames
, on Flickr
PXL_20240423_000903897
by
Kevin Ames
, on Flickr
PXL_20240423_234441280
by
Kevin Ames
, on Flickr
Start of the exhaust. I want to run down to the running board area, side pipe style, and exit right at the back of the cab with turn outs
PXL_20240421_224058342
by
Kevin Ames
, on Flickr
PXL_20240421_224052450
by
Kevin Ames
, on Flickr
PXL_20240420_223349164
by
Kevin Ames
, on Flickr
Approximate mounting location for the waste gates
PXL_20240428_191543150
by
Kevin Ames
, on Flickr
PXL_20240428_191537972
by
Kevin Ames
, on Flickr
Some welding I was happy with. Stainless is... different but I'm starting to like it since I've somewhat developed a good method.
PXL_20240428_234304625.MP
by
Kevin Ames
, on Flickr
PXL_20240428_191535359
by
Kevin Ames
, on Flickr
PXL_20240504_173356448
by
Kevin Ames
, on Flickr
PXL_20240504_173405351
by
Kevin Ames
, on Flickr
PXL_20240504_173346721
by
Kevin Ames
, on Flickr
And, after all that work...I hated it. It doesn't fit the look. Bad flow. Bad lines. Whatever you call it, it wasn't right.
I took the turn outs I made and repurposed them into the entire exhaust. I like the look way better.
PXL_20240504_201835749
by
Kevin Ames
, on Flickr
PXL_20240504_180540161
by
Kevin Ames
, on Flickr
PXL_20240504_201832240
by
Kevin Ames
, on Flickr
Over the next two weeks I'm going to be working on wiring and plumbing. Mid month it's going to my friends shop and he's building a full cage for the cab as well as a roll bar for the bed. We'll do some other things while it's there like build supports for the turbos, some intake piping and maybe some brake line work.
Gonna be a whirlwind
Last Edit: May 05, 2024, 09:56:17 AM by Monsterlover
Mother
Free Organic Individual
Reply #545 on:
May 05, 2024, 10:33:45 AM »
1) I have an erection
2) that PCM access hatch is a fantastic idea
3) what’s your plan for the oil lines?
Cool make the beast with two backsing truck
found my old skin suit
Reply #546 on:
May 05, 2024, 10:44:51 AM »
Quote from: Mother on May 05, 2024, 10:33:45 AM
Braided AN feed (-4 I think?) and -10 drains
Reply #547 on:
May 06, 2024, 12:48:38 AM »
Love all the work!
Love the look of the project!
The exhaust is unimaginative. Even if the ~15” straight section of pipe before the turn out had a slight bend in it… would look better IMO
Reply #548 on:
May 06, 2024, 02:14:10 AM »
Quote from: Duck-Stew on May 06, 2024, 12:48:38 AM
Love all the work!
Bend in which direction?
Reply #549 on:
May 06, 2024, 11:44:37 PM »
Parallel to the body panel line below would be better. It’s a few degrees off.
Or, put a large radius bend in it so that the pipe ends up vertical before the slash-cut outlet.
Last Edit: May 06, 2024, 11:48:11 PM by Duck-Stew
Reply #550 on:
May 07, 2024, 01:48:48 AM »
Put another way:
It seems to me that you respect the hell out of the original hood and have worked hard to keep it. So, with that in mind, the decision of exhaust pipe design should also mirror that respect for the original body lines and pieces/parts.
Enjoying the ride
Reply #551 on:
May 09, 2024, 10:44:14 AM »
Sorry, late to the party ...
Did you rotate the IN side of the turbo 180°?
Reply #552 on:
May 09, 2024, 10:52:34 AM »
Quote from: DarkMonster620 on May 09, 2024, 10:44:14 AM
The compressor housings and the center section are both loose right now. Neither of them are in their permanent orientation yet
Enjoying the ride
Reply #553 on:
May 09, 2024, 10:53:26 AM »
Quote from: Monsterlover on May 09, 2024, 10:52:34 AM
Reply #554 on:
May 10, 2024, 06:18:48 PM »
The mill was slow this week so I had my mill guy making truck parts.
First up was this shift boot trim ring I designed. After a design change and 3d printing a second prototype to check the fit it was time to make an aluminum piece.
About 8hrs all in to get through this one start to finish (program, setup, running tools in to check sizes etc)
PXL_20240509_210939708
by
Kevin Ames
, on Flickr
And along with that, the shifter. Inspiration struck and I made this one instead of the aluminum one I designed. I like that it's simpler and that I was able to incorporate the speed slots like I did on my radius rods, just scaled down.
Inserts were machined and the slots in the tube fitted to them. I left a .05" recess on each side to allow room to weld them in.
PXL_20240510_185104127
by
Kevin Ames
, on Flickr
PXL_20240511_020745556
by
Kevin Ames
, on Flickr
PXL_20240511_020805398
by
Kevin Ames
, on Flickr
PXL_20240511_020731832
by
Kevin Ames
, on Flickr
PXL_20240511_020653367
by
Kevin Ames
, on Flickr
PXL_20240511_020632284
by
Kevin Ames
, on Flickr
I left 2" extra on the shifter to set the right height after the knob gets here.
I ordered a plain white resin ball
Last Edit: May 10, 2024, 06:21:24 PM by Monsterlover
36
37
38
