October 20, 2024, 11:10:44 AM
Statler
ML builds an old truck
38
39
Topic: ML builds an old truck (Read 52986 times)
The best kind of whore is a
Re: ML builds an old truck
Reply #570 on:
October 06, 2024, 11:03:03 AM »
I haven't had much time to update and I'm finally getting around to posting pictures from the last couple months.
Wiring stuff
PXL_20240608_223119747
by
Kevin Ames
, on Flickr
PXL_20240608_222441675
by
Kevin Ames
, on Flickr
PXL_20240608_223051998
by
Kevin Ames
, on Flickr
Decided to make an aluminum bracket for my fuel filter that welds to the fuel cell. I initially bent one from 3/16 plate but it came out pretty ugly so I ended up milling one out of a solid block. Being that it ended up a lot thicker than the fuel cell it was a little bit of a challenge to weld. The big block kept sucking all the heat out of the weld so my beads look like caterpillars but it's stuck permanently so that's fine.
PXL_20240601_005129315
by
Kevin Ames
, on Flickr
Time to modify the intake for a blow off valve
PXL_20240609_181350819
by
Kevin Ames
, on Flickr
PXL_20240609_190400784
by
Kevin Ames
, on Flickr
PXL_20240609_191227529
by
Kevin Ames
, on Flickr
PXL_20240609_191642942
by
Kevin Ames
, on Flickr
PXL_20240609_205529325
by
Kevin Ames
, on Flickr
PXL_20240609_205429067
by
Kevin Ames
, on Flickr
Fitted the VIN/ ID tag in the factory location. It was really faded but since the numbers were stamped from the back side I was able to shine them up a little bit with 2000 grit sandpaper and some water. It's actually readable now
PXL_20240623_192804819
by
Kevin Ames
, on Flickr
The wiring is turning into 10 lb of shit in a 5 lb bag and continues to worsen...
PXL_20240623_203841484
by
Kevin Ames
, on Flickr
My main power/ ignition/ signal and headlight panel
PXL_20240623_182638679
by
Kevin Ames
, on Flickr
It is also 10 lb of shit in a 5 lb bag
PXL_20240623_172326203
by
Kevin Ames
, on Flickr
PXL_20240623_182632913
by
Kevin Ames
, on Flickr
PXL_20240623_172035309
by
Kevin Ames
, on Flickr
PXL_20240623_185806459
by
Kevin Ames
, on Flickr
Fuel filter mount welded
PXL_20240615_173330750
by
Kevin Ames
, on Flickr
PXL_20240615_173338967
by
Kevin Ames
, on Flickr
PXL_20240615_181516898
by
Kevin Ames
, on Flickr
PXL_20240615_181551229
by
Kevin Ames
, on Flickr
Ratchet strap to the rescue for holding it in place for welding
PXL_20240615_171630237
by
Kevin Ames
, on Flickr
Decided to 3D print an adapter to fit my Holley digital dash to the factory gauge opening. It was actually too wide to fit on my machine so I was able to add a dovetail and slice the model and print it in two sections. There is a slight seam from where they fit together but it's not too noticeable.
PXL_20240704_143005209
by
Kevin Ames
, on Flickr
3d printed version compared to the original metal piece
PXL_20240704_143356002
by
Kevin Ames
, on Flickr
PXL_20240704_143335292
by
Kevin Ames
, on Flickr
PXL_20240704_143304934
by
Kevin Ames
, on Flickr
PXL_20240704_143533527
by
Kevin Ames
, on Flickr
PXL_20240704_143913223
by
Kevin Ames
, on Flickr
PXL_20240721_000919291
by
Kevin Ames
, on Flickr
PXL_20240721_000912275
by
Kevin Ames
, on Flickr
3d printed mount for my flasher relays
PXL_20240721_001053927
by
Kevin Ames
, on Flickr
PXL_20240720_221620231
by
Kevin Ames
, on Flickr
Rather than use paint I used a chemical from the gunsmithing world, cold bluing, to essentially black oxide my steering shaft adapter and my steering rack adapters
PXL_20240720_233017895
by
Kevin Ames
, on Flickr
PXL_20240703_003314747
by
Kevin Ames
, on Flickr
Reply #571 on:
October 06, 2024, 11:48:15 AM »
I added the front brakes. I forgot how big F-250 brakes are.
PXL_20240720_214225781
by
Kevin Ames
, on Flickr
And even though it's not running yet my wife is technically the first person to drive it. We pushed it out of the garage while she steered. It got winched up onto a trailer for transport to my friends shop for roll cage work and to finish the build.
PXL_20240722_223037633
by
Kevin Ames
, on Flickr
Since the fuel cell and intercooler water reservoir are mounting in the bed I wanted a cool bracket to mount bulkhead fittings too rather than just directly to the bed. This is what I came up with.
PXL_20240710_142816318
by
Kevin Ames
, on Flickr
Topside
PXL_20240710_142934610
by
Kevin Ames
, on Flickr
Bottom side
PXL_20240710_142940228
by
Kevin Ames
, on Flickr
Intercooler radiator mounted in the grill of the truck
PXL_20240707_000940833
by
Kevin Ames
, on Flickr
It's a tight fit but everything on this truck is
PXL_20240709_230029646.MP
by
Kevin Ames
, on Flickr
Fan and shroud for the intercooler radiator
PXL_20240802_023424630
by
Kevin Ames
, on Flickr
PXL_20240802_023429090
by
Kevin Ames
, on Flickr
PXL_20240802_024018625
by
Kevin Ames
, on Flickr
Gotta have that bad boy air horn!
PXL_20240731_222041164
by
Kevin Ames
, on Flickr
PXL_20240801_011142948
by
Kevin Ames
, on Flickr
The main hoop. The cage begins.
PXL_20240725_005200645
by
Kevin Ames
, on Flickr
PXL_20240807_020407436
by
Kevin Ames
, on Flickr
PXL_20240807_022612199
by
Kevin Ames
, on Flickr
PXL_20240807_020405406.MP
by
Kevin Ames
, on Flickr
PXL_20240802_184703568.MP
by
Kevin Ames
, on Flickr
PXL_20240808_025856810
by
Kevin Ames
, on Flickr
PXL_20240808_030759432.MP
by
Kevin Ames
, on Flickr
PXL_20240814_015511810.MP
by
Kevin Ames
, on Flickr
PXL_20240815_015158622
by
Kevin Ames
, on Flickr
PXL_20240730_213220690
by
Kevin Ames
, on Flickr
PXL_20240730_213333521
by
Kevin Ames
, on Flickr
PXL_20240730_213335160
by
Kevin Ames
, on Flickr
Software makes it happen
PXL_20240828_023034673.MP
by
Kevin Ames
, on Flickr
Machining my patented speed slots
PXL_20240816_170922573
by
Kevin Ames
, on Flickr
I was able to fit it in there by commanding the tool change door to open and stay open during the machining process
PXL_20240816_170926990.MP
by
Kevin Ames
, on Flickr
Video of some of the machining
https://photos.app.goo.gl/vH5AVcVKBzCMYBow7
PXL_20240820_175528305.MP
by
Kevin Ames
, on Flickr
Inserts fit and welded
PXL_20240825_015852657
by
Kevin Ames
, on Flickr
PXL_20240825_015846321
by
Kevin Ames
, on Flickr
PXL_20240828_022603690
by
Kevin Ames
, on Flickr
PXL_20240828_022326826.MP
by
Kevin Ames
, on Flickr
PXL_20240828_022321551
by
Kevin Ames
, on Flickr
My friend tacking things together running the pedal like Suzanne Somers and the thigh Master
PXL_20240828_020037980
by
Kevin Ames
, on Flickr
PXL_20240828_010022270
by
Kevin Ames
, on Flickr
PXL_20240828_005949756
by
Kevin Ames
, on Flickr
Feet for the bed bars. I ended up making them like this but decided I hated the flower look and remade them with a round profile instead. The round profile better matched the plates that the bars attached to the cab with.
PXL_20240830_213655302
by
Kevin Ames
, on Flickr
The finished product with the mating half that goes underneath the bed. Everything bolts through and the two halves sandwich the bed.
PXL_20240904_230829252
by
Kevin Ames
, on Flickr
And the final round version. Notice those sweet stainless 12-point bolts? I had a lot of money wrapped up in stainless 12-point bolts LOL. They look right though.
PXL_20240928_043331892.MP
by
Kevin Ames
, on Flickr
PXL_20240928_043340947
by
Kevin Ames
, on Flickr
by
Kevin Ames
, on Flickr
PXL_20240913_021346755
by
Kevin Ames
, on Flickr
Since we couldn't go to the floor with door bars we came up with these mounts that welded to the kick panel. The receiver plate welds around a hole on its inside and this will bolt to that. The doorbar will weld to this. Rough machined-
PXL_20240829_205802405
by
Kevin Ames
, on Flickr
Finished
PXL_20240829_195625287
by
Kevin Ames
, on Flickr
PXL_20240827_232623086
by
Kevin Ames
, on Flickr
PXL_20240827_232629917
by
Kevin Ames
, on Flickr
All those chips from one part
PXL_20240829_205756062
by
Kevin Ames
, on Flickr
Door bars bent
PXL_20240821_233225373
by
Kevin Ames
, on Flickr
Receiver plate tacked in.
PXL_20240918_221726655
by
Kevin Ames
, on Flickr
Test fitting the bars
PXL_20240918_213054127
by
Kevin Ames
, on Flickr
PXL_20240918_213043964
by
Kevin Ames
, on Flickr
PXL_20240928_043542837
by
Kevin Ames
, on Flickr
PXL_20240928_043536946
by
Kevin Ames
, on Flickr
Tacking the windshield bar into place
PXL_20240926_005150364.MP
by
Kevin Ames
, on Flickr
Drop the whole thing down so the top can be welded
PXL_20240926_005827304
by
Kevin Ames
, on Flickr
Last Edit: October 06, 2024, 12:01:44 PM by Monsterlover
Reply #572 on:
October 06, 2024, 12:01:54 PM »
Finished cage
PXL_20240928_043549747
by
Kevin Ames
, on Flickr
PXL_20240928_043529678
by
Kevin Ames
, on Flickr
PXL_20240928_043519169
by
Kevin Ames
, on Flickr
PXL_20240928_043503087
by
Kevin Ames
, on Flickr
PXL_20240928_043309074
by
Kevin Ames
, on Flickr
PXL_20240926_011540671
by
Kevin Ames
, on Flickr
PXL_20240928_043229068
by
Kevin Ames
, on Flickr
PXL_20241004_194851834
by
Kevin Ames
, on Flickr
PXL_20241004_194858283
by
Kevin Ames
, on Flickr
PXL_20241004_194131584
by
Kevin Ames
, on Flickr
PXL_20241004_194139046
by
Kevin Ames
, on Flickr
PXL_20241004_194116642
by
Kevin Ames
, on Flickr
Mach up of the fuel cell, battery box and ic tank so we can mach up the radiator mount
PXL_20241004_194733849
by
Kevin Ames
, on Flickr
PXL_20241004_194751264
by
Kevin Ames
, on Flickr
Randimus Maximus
'01 996SPS
Reply #573 on:
October 06, 2024, 01:42:01 PM »
Looks great!!
you may be a god
1.21GW
bikeless
Reply #574 on:
October 06, 2024, 02:17:27 PM »
Forget the hood---can't you just roll down the highway Mad Max style looking like this?
Looking great, K!
Last Edit: October 06, 2024, 02:56:17 PM by 1.21GW
Reply #575 on:
October 06, 2024, 02:21:49 PM »
Hehe, I guess I *could* do that but I love the grill too much.
Reply #576 on:
October 07, 2024, 05:10:16 AM »
Whole lot of fabrication
Reply #577 on:
October 07, 2024, 05:26:54 AM »
Quote from: Howie on October 07, 2024, 05:10:16 AM
I didn't exactly keep track but my best estimate is that the cage and bed bars are something like 400 man hours.
That's not including time to machine the slots and inserts for the bed bars or the time to weld them in.
Reply #578 on:
October 07, 2024, 01:57:50 PM »
Looks like an 11ty billion dollar build to me.
Reply #579 on:
October 07, 2024, 02:24:41 PM »
At least...
Enjoying the ride
Reply #580 on:
October 08, 2024, 09:52:44 AM »
Looking great, very nice
Reply #581 on:
October 08, 2024, 03:13:04 PM »
I got to see a lot of the roll cage fab in person.
ML, and his buddy, has skillz!
Speedbag
And the Intrepid
Since 2004!
Reply #582 on:
October 15, 2024, 07:09:35 AM »
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Reply #583 on:
October 15, 2024, 01:33:22 PM »
Quote from: ducpainter on October 08, 2024, 03:13:04 PM
..some skills indeed
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
38
39
