ML builds an old truck
Started by Monsterlover, March 19, 2021, 07:59:32 PM
Good thing you know a guy with a machine shop. :P
It would be wrong not to use my powers for evil
Without a doubt...
However it would cost you a make the beast with two backs ton more if you had to pay retail. ;D
Quote from: ducpainter on November 18, 2024, 05:10:34 PM
Without a doubt...
Nobody likes paying retail
More progress pics
Bulkhead plates for the radiator hard lines to pass through the bed
PXL_20241120_013443731 by Kevin Ames, on Flickr
Cool shot of the truck on the lift
PXL_20241121_034154449 by Kevin Ames, on Flickr
PXL_20241121_034134325 by Kevin Ames, on Flickr
PXL_20241122_010414531 by Kevin Ames, on Flickr
PXL_20241122_010406476 by Kevin Ames, on Flickr
Radiator hard lines under the truck. We got both of these bent and fit with almost no fuss. Only one radius needed a slight unbending.
PXL_20241122_005323735 by Kevin Ames, on Flickr
PXL_20241122_005313587 by Kevin Ames, on Flickr
PXL_20241122_005303295 by Kevin Ames, on Flickr
PXL_20241122_005255312 by Kevin Ames, on Flickr
PXL_20241121_035204723 by Kevin Ames, on Flickr
I needed some cool nuts to hold my battery box lid on place. Wing nuts wouldn't do it. Need pointy.
PXL_20241205_001229951 by Kevin Ames, on Flickr
PXL_20241205_001234998 by Kevin Ames, on Flickr
PXL_20241205_193311154 by Kevin Ames, on Flickr
Intercooler pump, Bosch unit
PXL_20241203_200040701 by Kevin Ames, on Flickr
Turbo supports got powder coated
PXL_20241203_193559372 by Kevin Ames, on Flickr
-8 AN fuel lines and bulkhead plate
PXL_20241127_044749075 by Kevin Ames, on Flickr
Got the o2 sensor bungs welded into place
PXL_20241210_230302567 by Kevin Ames, on Flickr
A big tube/grommet I 3D printed to act as a wire conduit into the battery box. I didn't want any external wires showing if at all possible
PXL_20241210_032720998 by Kevin Ames, on Flickr
PXL_20241210_032810608.MP by Kevin Ames, on Flickr
Installed a lube - locker rear end gasket and 12pt stainless flange head bolts
PXL_20241211_015319467 by Kevin Ames, on Flickr
PXL_20241211_015327201 by Kevin Ames, on Flickr
PXL_20241211_015334775 by Kevin Ames, on Flickr
I don't have more pics of it currently but I bought a cheap aluminum vacuum manifold of Amazon and it only came with one end cap and I need two. It did, however, come with hose barbs that screw into the ends.  I turned one of them into an end cap by band sawing the barb off, flattened it with a sander and welded the hole closed, then dressed it on the sander again. I'll powder coat it black to match the black anodized manifold.
PXL_20241223_213731126 by Kevin Ames, on Flickr
The work continues...
Kopfjager
Randimus Maximus
Will there be a shield of sorts for the radiator lines that aren't steel?
Quote from: Randimus Maximus on December 28, 2024, 04:42:01 PM
No plan for one since it's on road only.
herm
This map is upside down, the plan is written in crayon, and the weather forecast is from 2011.
Randimus Maximus
Quote from: Monsterlover on December 28, 2024, 04:52:20 PM
Makes sense, and now that I look again, I see that it is towards the rear, so less chance of damage from road debris.
Langanobob
A really inspirational project!  There has to be a better word than inspirational but I don't know what it is.  Just curious what welding machine are you using?  I have an old Miller 250HF that I use for TIG and it seems everyone else is using  newer inverter machines.  Also, I saw your pic with the foot pedal between your knees.  I haven't tried one of those slider or thumb wheel controls but they might be useful.
Quote from: Langanobob on December 29, 2024, 08:11:28 PM
Glad you like the build so far.
At home I have an old Miller synchrowave 180sd, non inverter and a 255amp century mig welder.
At my friend's shop I've been using his Everlast inverter tig and it's a bad lady.  Lots of adjustments my 180sd doesn't have.
I can do ac/dc  and adjust the cleaning/pen on ac but that's it other than amperage.
The Everlast machine let's you adjust ac frequency as well which has a huge affect on the bead in aluminum.
I've found mild steel to be the most finicky and even with his fancy machine I had trouble keeping it from getting way too hot. That's more about technique and hanging around with people that know that they're doing has helped me tremendously.
I have a thumb wheel for my machine at home.  I hate it and use the pedal. It's all preference.
Thigh master style actually works pretty well and is really more controllable than you'd think. Try it on some practice tacks some time. You may be surprised.
