September 27, 2024, 10:55:52 AM
Please Help
Statler
ML builds an old truck
37
38
Topic: ML builds an old truck (Read 51538 times)
Feral 859
Re: ML builds an old truck
Reply #555 on:
May 10, 2024, 06:32:56 PM »
Reply #556 on:
May 10, 2024, 07:03:19 PM »
Nice!
Reply #557 on:
May 11, 2024, 10:18:39 AM »
The best kind of whore is a
Reply #558 on:
June 02, 2024, 03:11:58 PM »
Photo dump
I love my new HF portaband (corded) but sometimes you have to answer the OSHA gods and use it like this
PXL_20240514_230824805.MP
by
Kevin Ames
, on Flickr
Waste gate welds. Some of them came out ok
PXL_20240516_022821178
by
Kevin Ames
, on Flickr
O2 sensor going here
PXL_20240518_001846386.MP
by
Kevin Ames
, on Flickr
More welds. Starting to like working with stainless.
PXL_20240516_022825062.MP
by
Kevin Ames
, on Flickr
Shortened the shift rod and welded on the threaded adapter I made
PXL_20240518_020223281
by
Kevin Ames
, on Flickr
Plain white ball for the knob
PXL_20240518_021114434
by
Kevin Ames
, on Flickr
Didn't have enough bends on hand and didn't want to buy more so I made some from straight tubing
PXL_20240518_212749604
by
Kevin Ames
, on Flickr
The Y adapter came from eBay
PXL_20240518_214955054
by
Kevin Ames
, on Flickr
Cold side plumbing
PXL_20240519_205919967
by
Kevin Ames
, on Flickr
PXL_20240519_205924964
by
Kevin Ames
, on Flickr
PXL_20240519_205935815
by
Kevin Ames
, on Flickr
PXL_20240519_205944500
by
Kevin Ames
, on Flickr
Starting the other side
PXL_20240521_014726477
by
Kevin Ames
, on Flickr
PXL_20240525_234333388
by
Kevin Ames
, on Flickr
PXL_20240525_234225031
by
Kevin Ames
, on Flickr
Fully welded the first side and oh boy did it shift. I had to cut a section out and reweld to get it close enough
PXL_20240525_182708819
by
Kevin Ames
, on Flickr
PXL_20240525_234217050
by
Kevin Ames
, on Flickr
Both compressors have been reclocked to even out the look of the intake tubes running under the hood sides.
PXL_20240525_234459090
by
Kevin Ames
, on Flickr
Fuel pressure regulator all mounted up
PXL_20240527_210124006
by
Kevin Ames
, on Flickr
That's it for now. I have ordered a bunch of AN fittings and hoses and have almost all my wiring harnesses here now so I can start on those things.
Progress continues...
Reply #559 on:
June 02, 2024, 04:58:44 PM »
Reply #560 on:
June 02, 2024, 05:03:57 PM »
Looks wicked
Welds are lookin good!
Feral 859
Reply #561 on:
June 02, 2024, 05:27:42 PM »
Oh hell yeah!!
Randimus Maximus
'01 996SPS
Reply #562 on:
June 02, 2024, 07:48:59 PM »
Damn! Looking great!
you may be a god
For $50 you can touch my
Reply #563 on:
June 04, 2024, 02:41:44 PM »
Love it.
Fuel pressure regulater mounted to a rusty firewall?
Speedbag
And the Intrepid
Since 2004!
Reply #564 on:
June 05, 2024, 06:58:30 AM »
I like where this is going.
Where does the radiator get to live? Looks crampedish up there.
Reply #565 on:
June 05, 2024, 11:30:44 AM »
Quote from: Howie on June 02, 2024, 05:03:57 PM
Looks wicked
Thank you!
Quote from: Popeye the Sailor on June 04, 2024, 02:41:44 PM
Love it.
Any rust you see on the firewall is just surface rust. There are actually aluminum spacers between that aluminum plate and the firewall. All the bolts that hold that panel in place go through the firewall and through the frame that holds the pedals. It's all one large assembly to sandwich the firewall and spread the load from the pedals over a larger area.
I added the aluminum plate on the engine side just to give me a clean and raised surface to mount things too as needed.
It's easy to drill it out and add a riv nut.
Quote from: Speedbag on June 05, 2024, 06:58:30 AM
That is an understatement. There will be a radiator in the nose but it's a 12x12x2 in thick and will be used for cooling intercooler water only.
At the end of the month it will be at my buddy's shop for a full cage and bed bars.
We are mounting the radiator for the engine on the bed bars along with the fans and shroud.
Will it cool as good as a front mount radiator, probably not. I expect the fans to run a little more often than they normally would but I don't think overheating is going to be an issue.
Speedbag
And the Intrepid
Since 2004!
Reply #566 on:
June 06, 2024, 05:31:32 AM »
Quote from: Monsterlover on June 05, 2024, 11:30:44 AM
Well, off road racers use rear-mount radiators without issue. It'll look cool too. Plus a shit ton of coolant volume.
Reply #567 on:
June 06, 2024, 06:07:06 AM »
Quote from: Speedbag on June 06, 2024, 05:31:32 AM
Yeah those are my thoughts as well.
yamifixer
Reply #568 on:
June 06, 2024, 07:43:22 AM »
After seeing where the turbos are living i am VERY pro front fender.
Looks great BTW
Valve Springs are EVIL
Reply #569 on:
June 06, 2024, 07:49:57 AM »
Quote from: yamifixer on June 06, 2024, 07:43:22 AM
Looks great BTW
Thanks man. I definitely do like the way it looks with fenders on it. Probably equally as much as I like the way it looks without them.
My issue is I have widened the front track so much that the original fenders will no longer work to cover the wheels and it's not even close.
The front fenders have a convenient rib that runs front to rear that I could cut them there but I would have to widen them like 12 or 14" and it would just look too strange losing the original fender shape.
Maybe I'll try for fenders on the next one
37
38
