September 01, 2024, 01:34:18 AM
88
89
90
91
191
Topic: Plastic Tank problems: Discussion thread, see info thread sticky for updates (Read 699743 times)
Re: Plastic Tank problems: Discussion thread, see info thread sticky for updates
Reply #1320 on:
January 05, 2011, 11:03:20 AM »
Quote from: howie on January 05, 2011, 01:17:32 AM
Well, sort of. The warranty is 5 years or 30,000 kilometers, whichever comes first. They have been replacing tanks on bikes over 30K. The emissions warranty also does not include cosmetic problems. Unless fuel or fuel vapor is escaping there is no emissions defect. For some reason I will not speculate on they are using the emission warranty as a mechanism for replacing bad tanks.
my tank got replaced when i was at 22,000mi, ~ 35,000km
pianoman011
Reply #1321 on:
January 05, 2011, 12:59:58 PM »
Okay. I just did the Caswell Coating to my brand new Monster S4RS replacement tank. I used the entire contents for one application to this tank. It coated the entire tank except for one small spot at the back bottom of the tank at the opening. After I mixed the entire contents of the kit along wit 1/2 once of paint thinner, I poured it all in the tank and swirled, shacked, and any other way of moving it around in the tank, I went to pour out the excess and there was very little. I let it sit upside down for a few minutes and nothing came out. So I set the tank on some plastic the same way it would sit on the bike until the next morning and there was only a small 1 inch drop that came out. So my advice to anyone using this to use the entire kit on one tank to get it to cover in its entirety. I will have to coat the small area that didn't get the coating with the extra kit that I purchased for my 1098R Bayliss. It is really a very easy process
and the coating is hard as a rock inside. You can definitely tell where the coating is and where it is not. I hope to have the finished product ready by the end of the week. Then i can start on my Bayliss tank.
2007 Ducati Monster S4RS White / Red
2009 Ducati 1098R Bayliss Limited Edition
2011 Harley Davidson Street Glide
BoDiddley
S4Rs In Michigan
Reply #1322 on:
January 06, 2011, 03:11:21 PM »
Quote from: pianoman011 on January 05, 2011, 12:59:58 PM
If you had to do it again would you use two aplications at ounce instead of the one? I picked up my S4Rs tank today.
"But sire what are we to do. You have taken all our weapons and now the heathen hordes are at the gate. Are we to lie down and give them our lives. Without weapons they will make us eat ourselves."
pcv57
Reply #1323 on:
January 07, 2011, 10:07:33 AM »
Quote from: BoDiddley on January 06, 2011, 03:11:21 PM
I have an 06 s2r1k and had the tank replaced this summer due to swelling. I have now noticed my new tank has started to swell also. I have ordered the Caswell Coatings epoxy, will drain the tank and bring it inside where I hope it will shrink back before I do the coating.
According to a posting on this forum, it appears the swelling is due to ethanol in the gas and that the ethanol separates from the gas and causes condensation. The water in the tank sinks and is what is abosrbed by the plastic. If this is true, has anyone tried the Star Tron fuel additive? It is supposed to keep the ethanol from separating and it would seem to minimize the effects of the ethanol.
Reply #1324 on:
January 07, 2011, 10:33:53 AM »
I use Startron, but more to keep the effects of the separated ethanol from becoming a driveability issue.
I also have a steel tank.
mjk778
Reply #1325 on:
January 07, 2011, 04:08:37 PM »
Do you guys use Startron in every tank fill? I'm thinking of using for the effects of ethanol on my engine.
Last Edit: January 07, 2011, 04:10:59 PM by mjk778
Reply #1326 on:
January 07, 2011, 04:12:27 PM »
Quote from: mjk778 on January 07, 2011, 04:08:37 PM
Do you guys use Startron in every tank? Im thinking of using for effects of ethnol on my engine.
It depends on the season and the ride. If I'm out for a 300 mile day I don't add it every time I fill up. I might drop some in when I get home though. I always add it to the tank of my track bike after each day/weekend.
pianoman011
Reply #1327 on:
January 09, 2011, 06:28:28 AM »
Yes. I would 2 applications at one time on a brand new tank. One application covered 95% of the tank, but did leave a couple of places uncovered. I am waiting on my additional application to arrive so that I can finish the tank this week. So far I really like this product.
WetDuc
AKA iamhybris
Reply #1328 on:
January 09, 2011, 07:31:34 AM »
Without a doubt, the Startron/Stabil additives make my S2R1000 run much better.
I add it every to every tank to try to fight the ethanol, but regardless, it makes my bike run totally awesome: smoother idle and smoother under power, more torquey (my guess), better cold starts and a great tone at the exhaust note.
CDawg
S4RS
Reply #1329 on:
January 13, 2011, 09:51:03 AM »
6 month into Caswell on the replacement tank. No expansion yet.
Reply #1330 on:
January 13, 2011, 02:18:36 PM »
4 months in without any coating and no expansion. bikes been sitting in the garage and ive maybe passed 3 gallons through inthe past month (been snowing here) too.
hillbillypolack
Reply #1331 on:
January 15, 2011, 06:47:05 PM »
Has anyone had issues with the quality of the replacement tank (like in surface and aesthetics)?
I did an exchange today, the dealer let me bring in my tank (I removed it in the home shop) and we did the hardware swap. Upon closer inspection when I returned home, I saw an awful lot of orangepeel and a highlight issue at the tank filler surface:
http://sonar.smugmug.com/Other/S2R-tank-replacement/15464222_AqnAd
Last Edit: January 15, 2011, 07:13:35 PM by hillbillypolack
Bishamon
Reply #1332 on:
January 16, 2011, 06:15:50 AM »
Some Sport Classic owners have complained about the quality of the finish on their replacement tanks, but it seems to be hit-or-miss.
2011 Monster 796
2007 Sport 1000 SE (SOLD)
jgrm1
Reply #1333 on:
January 16, 2011, 09:14:12 AM »
Quote from: hillbillypolack on January 15, 2011, 06:47:05 PM
The finish on my replacement S2R1000 tank is fine, but the cutout on the strip is not centered around the fuel filler as well as the original one.
-Jeff
Last Edit: January 17, 2011, 09:12:17 AM by jgrm1
BMW: 2016 R1200RS, 2000 R1100S, 1975 R90S
Ducati: 2008 S2R1000, 1998 900 Supersport Final Edition
Norton: 1974 Commando 850
Triumph: 2016 Thruxton R, 1971 T120R
Desert Dust
Ten Most Popular Uses for a
Reply #1334 on:
January 16, 2011, 01:14:08 PM »
It has been 2 months since my S2R 1K tank was replaced, and there is no sign of swelling. No Caswell treatment was applied.
By the way, the new tank looks great as far as finish is concerned.
88
89
90
91
191
