GUN STUFF
Started by fastwin, June 26, 2010, 11:24:07 AM
Quote from: DRKWNG on December 29, 2011, 04:30:27 PM
Pretty sure that pic was done as a joke. Let's please keep things in line and not tread into dangerous ground.
I'm pretty sure it a p-chop.
Sense of humor required.
Quote from: ducpainter on December 29, 2011, 04:35:11 PM
That's my point.
Dannyboy
Got to shoot my buddy's Mac-10 yesterday.  I have to say, happiness is full auto.  Then as we were getting ready to leave, we started talking to the guy next to us about some of his guns, one of which was a WW2 Thompson.  He let us each put a mag through it.  Man, that thing was a tank but there was no recoil and muzzle rise was minimal.  Really fun to shoot.
Here's something you don't see all the time...
http://www.czfirearms.us/index.php?topic=44381.msg254566#msg254566
Get 'em while they're hot....
F!!  That's not a bad price on those bad boys.
Quote from: DRKWNG on December 31, 2011, 08:39:59 AM
So many toys...
so little money. :-\
WarrenJ
That looks like something I could easily get in trouble with!  If I have a small windfall, I might have to acquire one of them!!!!!
You can pick up a 37mm version of an M203 which is a smoothbore plastic barrel launcher without a DD tax.  You can reload the shells with black powder for a low pressure shell.
I think that as it stands doesn't need the DD tax.
I might be wrong.
Quote from: ducpainter on December 31, 2011, 11:16:38 AM
I might be wrong.
Smoothbore 25-26.5mm flares do not.
Once the barrel is steel, they look closer.
The 26.5 flare size has only ever had flares made for it, never high-enery projectiles or grenades.  You >could< make grenades with it, but not easily.  Same rules apply to rare-cartridge sizes above 0.50 caliber.  If the ammo is common-ish, then it's a DD, but if it's something you cooked up in your basement and that's the only source for the ammo, then it's not a DD.
For smoothbores, if it's above 0.50" then the question is what ammo is available.
That's why you see rifled slug guns in 12ga but nothing bigger.
a 40mm M203 is a DD because there is plenty of 40 mm shells which are grenade type.  You can reload the shells.  Flares are available, but so are grenades.
stateprez
Contemplating a 22lr AR15.  Anyone have any preferences- I was looking at the Sig and the HK?  Anything else I should look at?
'03 999 Mono
fastwin
Quote from: Dannyboy on December 30, 2011, 04:23:45 PM
Last summer I was hanging out with some Class III buddies at a shoot and one had a Mac-11 .380acp and oh my God was the rate of fire off the chart!! I think it's rated at around 1,250 rpm but damn, it seemed faster than that! :o And at the cost of .380acp ammo I bet it's not getting a lot of playing time! Still, major fun to shoot. Glad I got to borrow it and not own it. [thumbsup]
My brother owns a Class III .45acp Thompson. You're right, it does rock! [thumbsup] [popcorn] [bacon]
WarrenJ
#2534
As far as 22LR AR-15's, - I have a CMMG conversion kit that I really like(when its in my possession as my brother usually ends up with it).  Its very reliable and very accurate with certain types of ammo.  Accuracy varies from 12" @ 50 yards to less than a half inch at that range depending on the ammo.  My rig shows an extreme preference for Wolf Match Target.  It jams occasionally with the Wolf as it is a subsonic match round but it is by far the most accurate in my rig.  I've swapped the kit into other AR's and the ammo preferences change drastically.  My brothers AR shoots CCI MiniMag  real well.  If you get a rimfire AR, (or any 22 for that matter) collect up a wide variety of ammo and spend a few hours at the range, benching it to see what it likes.  The difference the right ammo makes can be dramatic.
One thing with testing a variety of rimfire ammo, when you switch from one brand to another, make sure to shoot 5-10 rounds of it before getting serious about grouping with it as it will take a few shots for the bore condition to adjust to the different lube/powder fouling characteristics of each individual ammo.  The difference getting to a consistent bore condition makes is very noticeable in an accurate rifle.
Typically with the AR 22's, you will find a high reliability ammo with adequate accuracy for blasting and probably a subsonic round that will be more accurate, but may jam a bit.
