February 23, 2025, 08:27:55 PM *
News: Please Help
Pages: 1 2 3 [4] 5 6 ... 8   Go Down
Author Topic: Street Fighter update  (Read 32275 times)
yotogi
« Reply #45 on: June 25, 2009, 08:29:57 AM »
True, if you were at redline, the engine can't rev up anymore, and a slipper is probably the best bet.
But, like the link Spidey added, some ECU's can reduce engine braking by allowing "leaks" into the cylinder chamber, which could also work, and which we will probably see more of incorporated into TC/ECU's for the street.
I could see a bypass valve on the cylinder working. Basically, you open that up and are running the bike with very little compression. Seems like a very complicated solution to the problem though with the necessary addition of a solenoid actuated valve. So many more parts to break and if it got stuck open, jeesh, no fun.
I don't have nearly enough of an understanding of valving on engine, but does anyone make a motor with solenoid actuated valves?
RetroSBK
« Reply #46 on: June 25, 2009, 06:32:51 PM »
Flyn - The bigger rear tire doesnt always equate to slower turn in. If it DOES effect turn in, you have some chassis issues to sort out. This really only applies when the chassis is well sorted. The stock SF is very conservative stock. This one is a bit closer now.
The IACS that you are talking about is not a function of TC and runs on top of the Management system. Most all the teams in GP and WSB have quit using the "auto-blip" althought some riders do use and prefer it. The IACS (Idle Air Control System) does NOT add fuel, as this would make power, and provide the exact opposite of the goal of the system, to completely eliminate engine braking. The AICS adds a it of air, either by injecting it, or by SLIGHTLY opening the throttle bodies for a second. This is designed to aid the wheel/engine back torque matching issues that can occur when using carbon/carbon brakes. This really isnt an issue with Steel brakes, as they cant provide enough power to cause these issues.
ALL that being said, there really isnt a top rider in the world that bangs downshifts at redline... If you watch the races, they do a LOT of braking before they get near the downshifts, and the downshifts come in very quick bunches.
Will
Will Kenefick's Retro Superbike. Bringing you the sickest Sh*t since '94
« Reply #47 on: June 26, 2009, 08:24:55 AM »
Yada Yada Yada, where's the pictures?!
Grin
SikDuc
07 S4Rs
« Reply #48 on: June 26, 2009, 09:46:41 AM »
Grin
+1
RetroSBK
« Reply #49 on: June 26, 2009, 07:02:32 PM »
ROFL...
Come see it at Laguna Seca!
Spidey
Crashin' mofo
« Reply #50 on: June 26, 2009, 07:05:02 PM »
A birdie told me you got your engine back.   Wink
RetroSBK
« Reply #51 on: June 26, 2009, 09:07:30 PM »
Yeah... Made Scotty do all the hard work.. I think he was a lil bit disapointed at the dungeon like setup in my shop!
I finished the exhaust today, welded up from 66 pieces of metal.. thats a hard day, let me tell you..
Scotty and Desmoto are the place, I tell ya!
« Reply #52 on: June 27, 2009, 12:24:51 PM »
ROFL...
I'm pretty much as far away from there as possible while still being in the same country...
RetroSBK
« Reply #53 on: June 28, 2009, 05:44:47 AM »
Ok...
It will be in Cycle World too....
Done now, save the muffler clamp... Exhaust is made up of SOO many pieces, its stupid
Anyone want a sneak preview pic?
« Last Edit: June 30, 2009, 12:04:30 AM by RetroSBK » Logged
yotogi
« Reply #54 on: June 30, 2009, 11:11:28 AM »
Yes please.  Smiley
Triple J
« Reply #55 on: June 30, 2009, 11:33:50 AM »
Yes please.  Smiley
+1
dbran1949
2007 S4RS Black Termis
« Reply #56 on: June 30, 2009, 11:36:36 AM »
no thanks, now that I'm 60 I'm drooling too much as it is  Tongue
Juan
« Reply #57 on: June 30, 2009, 01:34:06 PM »
post the pics please...!!
DucHead
No garage queens
« Reply #58 on: June 30, 2009, 01:50:24 PM »
THIS JUST IN:  THREAD IN DESPERATE NEED OF PICS! Grin
flanman
« Reply #59 on: June 30, 2009, 03:25:24 PM »
I bet its just a tease. Pics would be nice  Grin And don't say we're going to have to wait until its all done.
Pages: 1 2 3 [4] 5 6 ... 8   Go Up
