tutorial section thought...
Started by billg69gmc, November 11, 2008, 02:14:58 AM
billg69gmc
In the tutorial section, the manner in which everything is list can sometimes irk me.
I would not mind helping out, if it is possible... but I would like a tutorial section where you open the main page, and on the page a table page can be set up where the tutorials are list in proper alphabetical order/category. Do away with title text that say "tutorial" or "how to" and each topic would be part or process specific. Like main headings Engine, Frame, Electrical, Aftermarket... then sub headings in alpha with specific topics that are hyperlinked to the posts.
New posts would of course have to be added to the table, but it would allow someone to efficiently find what they are looking for. Since the original post would still hold the original hyperlink, it's just a maintenance issue with updating the "sticky" that would have the BIG LIST.
Let me know if you want help for this, I can post or email an example that is functional or at least try to and see how it works.
billg
2010 StreetFighter S     2008 Hym1100     2006 S2R1k
billg69gmc
I sorted through about every tut page and sorted them. If I can get it into a table without much effort or embed the hyperlinks it would look nicer... but here it is.
Drivetrain, Chain Installation ducatitech.com   http://ducatimonsterforum.org/index.php?topic=667.0
Drivetrain, Chain, Care and Maint. Ducatitech.com   http://ducatimonsterforum.org/index.php?topic=666.0
Drivetrain, Chain, Tensioning   http://ducatimonsterforum.org/index.php?topic=3038.0
Drivetrain, Clutch, Installing new dry clutch plates   http://ducatimonsterforum.org/index.php?topic=11240.0
Drivetrain, Clutch, Pressure Plate replacement   http://ducatimonsterforum.org/index.php?topic=350.0
Drivetrain, Clutch, spring replacement EZ   http://ducatimonsterforum.org/index.php?topic=2511.0
Drivetrain, Sprocket, Changing to 14t on S2R800   http://ducatimonsterforum.org/index.php?topic=510.0
Drivetrain, Sprocket, Install Quickchange ducatitech.com   http://ducatimonsterforum.org/index.php?topic=671.0
Drivetrain, Wheel Rear, Spool Installation   http://ducatimonsterforum.org/index.php?topic=1777.0
Drivetrain, Wheels, Removal/Installation Front Wheel   http://ducatimonsterforum.org/index.php?topic=10276.0
Drivetrain, Wheels, Wheel Bearing, Alternator, Clutch, Fuel Pump and more   http://ducatimonsterforum.org/index.php?topic=700.0
Electrical, Charging System   http://ducatimonsterforum.org/index.php?topic=14261.0
Electrical, Fixing broken tail light mount   http://ducatimonsterforum.org/index.php?topic=11243.0
Electrical, GPS Install   http://ducatimonsterforum.org/index.php?topic=10186.0
Electrical, HID Headlight   http://ducatimonsterforum.org/index.php?topic=12103.0
Electrical, Indicator switch repair   http://ducatimonsterforum.org/index.php?topic=5856.0
Electrical, Tachometer repair w/ pics   http://ducatimonsterforum.org/index.php?topic=878.0
Electrical/Frame, Lowering Headlight, Guages, Nose Fairing   http://ducatimonsterforum.org/index.php?topic=1050.0
Engine, 4V Cooling System   http://ducatimonsterforum.org/index.php?topic=12572.0
Engine, Belt Servicing, Desmoquatro   http://ducatimonsterforum.org/index.php?topic=11944.0
Engine, Belts, Loctited Allen Bolts on tensioner   http://ducatimonsterforum.org/index.php?topic=6142.0
Engine, Changing Plugs in S4R   http://ducatimonsterforum.org/index.php?topic=10820.0
Engine, Crankcase Breather Vent kit TPO Parts   http://ducatimonsterforum.org/index.php?topic=14114.0
Engine, Cylinder Replacement: What it takes   http://ducatimonsterforum.org/index.php?topic=3620.0
Engine, Desmoquatro Lubrication System   http://ducatimonsterforum.org/index.php?topic=13222.0
Engine, Ducatitech Oil Change   http://ducatimonsterforum.org/index.php?topic=410.0
Engine, Emissions Canister Removal   http://ducatimonsterforum.org/index.php?topic=2514.0
Engine, Fuel Level Sensor replace   http://ducatimonsterforum.org/index.php?topic=2512.0
Engine, milky sight glass   http://ducatimonsterforum.org/index.php?topic=12023.0
Engine, Oil Change skills critique   http://ducatimonsterforum.org/index.php?topic=4181.0
Engine, Oil Screen Removal   http://ducatimonsterforum.org/index.php?topic=12586.0
Engine, rocker pin removal no special tools   http://ducatimonsterforum.org/index.php?topic=2231.0
Engine, S2R800 Camshaft Options   http://ducatimonsterforum.org/index.php?topic=8495.0
Engine, Timing Belt repair ducatitech.com   http://ducatimonsterforum.org/index.php?topic=670.0
Engine, Valve Adjustment ducatitech.com   http://ducatimonsterforum.org/index.php?topic=669.0
Exhaust, Chop and Core and Lower   http://ducatimonsterforum.org/index.php?topic=2312.0
Exhaust, Coring S*R Cans   http://ducatimonsterforum.org/index.php?topic=505.0
Exhaust, painting cans 696   http://ducatimonsterforum.org/index.php?topic=11098.0
Exhaust, S4R System   http://ducatimonsterforum.org/index.php?topic=12501.0
frame sliders 696   http://ducatimonsterforum.org/index.php?topic=14823.0
Frame, Footpeg removal   http://ducatimonsterforum.org/index.php?topic=3079.0
Frame, Sliders installation   http://ducatimonsterforum.org/index.php?topic=9565.0
Frame, Tail Chop Bracket Schematic   http://ducatimonsterforum.org/index.php?topic=2938.0
Frame, Tail Chop LED Indicators in Frame   http://ducatimonsterforum.org/index.php?topic=1333.0
Frame, Triple Clamp Removal   http://ducatimonsterforum.org/index.php?topic=919.0
Frame. Tail Chop, PDF instructions   http://ducatimonsterforum.org/index.php?topic=5641.0
Fuel System   http://ducatimonsterforum.org/index.php?topic=12274.0
Fuel Tank, how to prop up   http://ducatimonsterforum.org/index.php?topic=10384.0
Fuel, Cleaning Rust from Fuel tank   http://ducatimonsterforum.org/index.php?topic=3709.0
Fuel, get more in the 620 Multi   http://ducatimonsterforum.org/index.php?topic=1533.0
Fuel, Purging fuel/fumes from plastic tanks   http://ducatimonsterforum.org/index.php?topic=4623.0
General, Performing maintenance and modifications   http://ducatimonsterforum.org/index.php?topic=6505.0
General, Torque Values   http://ducatimonsterforum.org/index.php?topic=4841.0
Handlebars, Heated Grips Installation   http://ducatimonsterforum.org/index.php?topic=2520.0
Handlebars, How to replace   http://ducatimonsterforum.org/index.php?topic=1365.0
Handlebars, Install Suburban Machinery Bars   http://ducatimonsterforum.org/index.php?topic=4416.0
Handlebars, Levers, Pazo install 696   http://ducatimonsterforum.org/index.php?topic=9633.0
Handlebars. levers 696   http://ducatimonsterforum.org/index.php?topic=14769.0
Manuals, 620 Dark Owners Manual   http://ducatimonsterforum.org/index.php?topic=10541.0
Misc, Cleaning / Detailing your Monster   http://ducatimonsterforum.org/index.php?topic=5002.0
Misc, How to screw up a great internet community   http://ducatimonsterforum.org/index.php?topic=1275.0
Misc, Modifications, making your Duc unique   http://ducatimonsterforum.org/index.php?topic=6965.0
Misc, Monkey Butt and Skin problems   http://ducatimonsterforum.org/index.php?topic=4567.0
Misc, Movie or Slideshow for Youtube   http://ducatimonsterforum.org/index.php?topic=5861.0
Misc, new bike break in procedure   http://ducatimonsterforum.org/index.php?topic=14748.0
Misc, Paint Touch up   http://ducatimonsterforum.org/index.php?topic=1767.0
Misc, Painting your Duc   http://ducatimonsterforum.org/index.php?topic=681.0
Misc, Pre Ride Checklist   http://ducatimonsterforum.org/index.php?topic=4170.0
Misc, Removing rounded out bolt   http://ducatimonsterforum.org/index.php?topic=292.0
Misc, Repair shifter thread   http://ducatimonsterforum.org/index.php?topic=2402.0
Misc, Seat, Gel Seat, making your own   http://ducatimonsterforum.org/index.php?topic=2513.0
Misc, Shop Service Manual, the best   http://ducatimonsterforum.org/index.php?topic=2336.0
Misc, Stickers, applying   http://ducatimonsterforum.org/index.php?topic=7514.0
Misc, Stud removal   http://ducatimonsterforum.org/index.php?topic=1554.0
Misc, Thread Repair   http://ducatimonsterforum.org/index.php?topic=14009.0
Misc, Traffic Light trigger   http://ducatimonsterforum.org/index.php?topic=6064.0
Misc, Trailer stowage for moving   http://ducatimonsterforum.org/index.php?topic=10158.0
Misc, Trailering in a 22 foot rental truck   http://ducatimonsterforum.org/index.php?topic=1548.0
Misc, Transporting your moto   http://ducatimonsterforum.org/index.php?topic=4075.0
Misc, Washing Your Ducati   http://ducatimonsterforum.org/index.php?topic=1758.0
Misc, Winter Storage   http://ducatimonsterforum.org/index.php?topic=4169.0
Misc, Zipper Help   http://ducatimonsterforum.org/index.php?topic=1595.0
Misc. How to Clean your visor in the field   http://ducatimonsterforum.org/index.php?topic=5314.0
Suspension, 998 vs 999 Shock   http://ducatimonsterforum.org/index.php?topic=11573.0
Suspension, Adjusting Preload   http://ducatimonsterforum.org/index.php?topic=13710.0
Suspension, Adjusting Ride Height S4RS   http://ducatimonsterforum.org/index.php?topic=10662.0
Suspension, Fork Oil Change   http://ducatimonsterforum.org/index.php?topic=14197.0
Suspension, S*R Read Hub   http://ducatimonsterforum.org/index.php?topic=13421.0
Suspension, S2R Rear Shock Installation   http://ducatimonsterforum.org/index.php?topic=8896.0
Tools, basic ducati tools   http://ducatimonsterforum.org/index.php?topic=12262.0
Tools, Make your own bike stand   http://ducatimonsterforum.org/index.php?topic=6180.0
Tools, Tools and Garage Resource Links   http://ducatimonsterforum.org/index.php?topic=351.0
Right now were working on getting the home page to work.
When that's done I'll look into your idea.
Someone suggested the same type of thing for the faq page.
Since you already posted this list over there I stickied and locked it.
I think that's the only way of doing it anyway.
Tried to improve the formatting but it's a lot of work.  Need a break. :P
Edit: found a better way to do it :)
Drivetrain    Chain Chain Installation (ducatitech.com)
Chain Care and Maintenance (ducatitech.com)
Tensioning
Clutch    Installing new dry clutch plates
Spring replacement EZ
Sprocket      Changing to 14t on S2R800
Install Quickchange (ducatitech.com)
Wheels    Rear Spool Installation
Electrical      Charging System
Fixing broken taillight mount
GPS install
HID headlight
Tachometer repair
Electrical/Frame      Lowering Headlight, Gauges, Nose Fairing
Engine      4V Cooling System
Belt Servicing, Desmoquattro
milky sight glass
Oil Screen Removal
Exhaust      Chop and Core and Lower
Coring S*R Cans
painting cans 696
S4R System
Frame    frame sliders 696
Footpeg removal
Fuel        Fuel System
how to prop up fuel tank
General      Performing maintenance and modifications
Torque Values
Handlebars    Heated Grips Installation
How to replace
levers 696
Manuals      620 Dark Owners Manual
Miscellaneous    Cleaning / Detailing your Monster
Paint Touch up
Painting your Duc
Pre Ride Checklist
Seat, Making your own Gel Seat
Stickers, applying
Stud removal
Thread Repair
Washing Your Ducati
Winter Storage
Zipper Help
Suspension      998 vs 999 Shock
Adjusting Preload
Fork Oil Change
S*R Read Hub
Tools      basic ducati tools
Spidey
#4
Now that there are more than just a coupla Tutorials getting them organized is great.   [thumbsup]
I've been independently toying with starting to get the FAQ section together in a similar fashion.  It would include the current FAQs, new FAQS written by whomever and the existing Tutorials.  That was the FAQ section's original intent.    I haven't done anything yet because (a) the DMF is still developing a library of knowledge here -- the TOB had years worth of info; (b) it's hard to get motivated to do it a second time; and (c) I've been doin' other stuff like riding.   ;D  It would be excellent if there was a small group of people specifically willing to put in the time to work on the FAQ section as a project.
herm
i like the idea of those boards getting organized, and also the idea of anyone with the time and inclination to help out.
but i also think its important that whatever final "organization" that takes place is uniform.
i.e -- if How-To gets set up to look like the example that msincredible posted above, then the FAQ should be set up the same way.
it would also be a good idea to have a "submit a FAQ" and "submit How To", similar to "report to moderator". essentially a PM function, this could either go to whichever mod picked it up, or to a designated individual. that person would review the post, to insure that it belonged in FAQ or How To, and then post it to the appropriate board. this would help to keep the "how do i....?" questions from overwhelming those boards.
anyway, thats my .02
spent now...
